주요 콘텐츠로 건너뛰기
iDevices iGrill Probe Replacement
필요한 것
  1. iDevices iGrill Probe Replacement, Probes: 1 단계, 이미지 1/1
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: 2 단계, 이미지 1/1
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: 3 단계, 이미지 1/2 iDevices iGrill Probe Replacement: 3 단계, 이미지 2/2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: 4 단계, 이미지 1/3 iDevices iGrill Probe Replacement: 4 단계, 이미지 2/3 iDevices iGrill Probe Replacement: 4 단계, 이미지 3/3
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: 5 단계, 이미지 1/1
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: 6 단계, 이미지 1/1
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
결론
Michelle Nguyen
회원 가입일: 02/16/16
204 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-4, Harley Spring 2016 IUPUI, Team 3-4, Harley Spring 2016 회원
IUPUI-HARLEY-S16S3G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 5
전체 시간: 1,051
