소개
Has your iFit stopped working? Have you tried Troubleshooting, but none of the suggestions worked? Replacing your battery may solve these problems.
필요한 것
Hold the iFit band in both hands, with your thumbs on either side of the tracker pod at the center of the wristband.
To assemble this device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
The directions state that battery CR2032 is the battery for the ifit.act. I purchased this battery and it does not fit. Where can I get the battery that is compatible with ifit.act?
The original battery should have identifying markings on the top so you can purchase an identical replacement. A standard CR 2032 coin cell battery is what’s specified by the manufacturer.
