주요 콘텐츠로 건너뛰기
iFixit 26 Bit Driver Kit Technique for Removing Bits
필요한 것
  1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: 1 단계, 이미지 1/1
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. iFixit 26 Bit Driver Kit Technique for Removing Bits: 2 단계, 이미지 1/1
    • Find yourself a rubber band...
  3. iFixit 26 Bit Driver Kit Technique for Removing Bits: 3 단계, 이미지 1/1
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  4. iFixit 26 Bit Driver Kit Technique for Removing Bits: 4 단계, 이미지 1/1
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
결론
다른 48명이 해당 안내서를 완성하였습니다.
aaronmiller
회원 가입일: 08/28/11
1,376 평판
안내서 1개 작성함
댓글 한 개
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 40
전체 시간: 4,687
