주요 콘텐츠로 건너뛰기
iFixit Side Stack Retail Display Assembly
  1. iFixit Side Stack Retail Display Assembly, Empty Box Components: 1 단계, 이미지 1개 중 1개
    • Box should include:
    • Set of screws/driver
    • Metal rods
    • Honeycomb Base/Feet
    • Main stand (back/sides)
    • Two large, one small foldable shelf insert
    • Two large, one small black rectangular insert
    • "You can fix it" panel and iFixit topper (not pictured)
  2. iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: 2 단계, 이미지 3개 중 1개 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: 2 단계, 이미지 3개 중 2개 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: 2 단계, 이미지 3개 중 3개
    • The three angled supports fit into the two rectangular supports.
    • Place the fully constructed honeycomb base into the display.
  3. iFixit Side Stack Retail Display Assembly, "You can fix it": 3 단계, 이미지 3개 중 1개 iFixit Side Stack Retail Display Assembly, "You can fix it": 3 단계, 이미지 3개 중 2개 iFixit Side Stack Retail Display Assembly, "You can fix it": 3 단계, 이미지 3개 중 3개
    • Fit “You can fix it” panel over front of honeycomb base
    • “You can fix it” panel sides fit INSIDE of base walls
    • Use screws to fasten
  4. iFixit Side Stack Retail Display Assembly, Build Shelf Insert: 4 단계, 이미지 3개 중 1개 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: 4 단계, 이미지 3개 중 2개 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: 4 단계, 이미지 3개 중 3개
    • Build bottom shelf, using one of two larger foldable shelves
    • Tabs fit together, fit side tabs along back, then fold over and secure
  5. iFixit Side Stack Retail Display Assembly, Install Metal Supports: 5 단계, 이미지 2개 중 1개 iFixit Side Stack Retail Display Assembly, Install Metal Supports: 5 단계, 이미지 2개 중 2개
    • Install two metal support for middle shelf
    • Metal rods fit into provided holes
  6. iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: 6 단계, 이미지 3개 중 1개 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: 6 단계, 이미지 3개 중 2개 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: 6 단계, 이미지 3개 중 3개
    • Fit bottom shelf into bottom shelf slots cut into back of display
    • Tabs go out the back and then back in towards the front
    • Lay black shelf insert into shelf
    • Fit screws together to hold shelf in place
    • Repeat for middle and top shelves
    • Top shelf and insert are smaller than bottom and middle shelves
  7. iFixit Side Stack Retail Display Assembly, Fold Sides into Honeycomb Base: 7 단계, 이미지 1개 중 1개
    • Like so.
    • (Go Angels!)
  8. iFixit Side Stack Retail Display Assembly, iFixt Header Sign: 8 단계, 이미지 2개 중 1개 iFixit Side Stack Retail Display Assembly, iFixt Header Sign: 8 단계, 이미지 2개 중 2개
    • Fold top section down to make holes match
    • Align iFixit sign and install using screws
결론
작성자
2다른 기여자 명과 함께
Eric Essen
회원 가입일: 06/04/10
18,012 평판
안내서 8개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,764개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 354
