주요 콘텐츠로 건너뛰기
iHealth Edge Motherboard Replacement
필요한 것
  1. iHealth Edge Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Lightly heat device with hair dryer for 15 seconds to soften adhesive.
  2. iHealth Edge Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • After heating adhesive, firmly pry apart the two halves.
  3. iHealth Edge Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove polymer cover that is protecting the mother board, it should just come out when two halves are separated.
  4. iHealth Edge Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use a pair of nylon spudgers to assist the removal of the motherboard. Pry up on two tabs and the mother board will pop out.
  5. iHealth Edge Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • This shows the mother board out and exposed.
  6. iHealth Edge Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • You must remove the solder from two wires from the motherboard that are connected to the battery.
결론
작성자
1다른 기여자 명과 함께
Gabrielle Bettegnies
회원 가입일: 08/23/17
349 평판
안내서 3개를 작성함
IUPUI, Team S1-G4, Freund Fall 2017 IUPUI, Team S1-G4, Freund Fall 2017 회원
IUPUI-FREUND-F17S1G4
4 회원들
안내서 3개를 작성함
2가이드 댓글
This guide will help show you how to replace the mother board on the iHealth Edge. You must take the device and remove the two piece that are stuck together using a blow dryer. This will expose the inside of the device to see screen. This is where we will begin to learn how to replace the motherboard.
Remove the word help in the first sentence. The guide will show you how to replace the mother board.
Following is a partial description of what needs to be on the device page. This is copied from the iFixit web site. I don’t think you’ve met these requirements.
-Includes thorough information describing the device and its background information to educate readers and aid them in identifying their device
-Lists at least three helpful, properly formatted links on the device page
Linda Freund - 답글
On Motherboard replacement guide, the last step is not needed.
How many wires need to be desoldered? If its more than one, you should give the number. Example: Use a soldering iron to remove 2 wires.
Looks good. I’m impressed. Lets see what iFixit says.
Linda Freund - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 424
