주요 콘텐츠로 건너뛰기
iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement
필요한 것
  1. iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Removing the battery case cover: 1 단계, 이미지 1/1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Cleaning the battery case: 2 단계, 이미지 1/3 iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Cleaning the battery case: 2 단계, 이미지 2/3 iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Cleaning the battery case: 2 단계, 이미지 3/3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Removing the screws: 3 단계, 이미지 1/2 iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Removing the screws: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Removing the back cover: 4 단계, 이미지 1/2 iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Removing the back cover: 4 단계, 이미지 2/2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Locating the DC IN 6V Adapter: 5 단계, 이미지 1/1
    • Position the portable speaker device so that the back cover and the speaker are both laying flat, giving you access to the inside of the device.
    • If the motherboard is at the bottom when you are looking down at the device, the DC IN 6V adapter should be on the right side of the back cover.
    • It is also labeled on the outside of the back cover in white font.
  6. iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Removing the adapter: 6 단계, 이미지 1/1
    • Remove the black and red wires attached to both the motherboard and the adapter by cutting them with scissors.
    • Repeat previous step for the blue and second black wire connecting the adapter to the battery case.
    • At this point, you should be able to carefully remove the entire faulty adapter and the wires.
  7. iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement, Assembling new adapter: 7 단계, 이미지 1/1
    • Position the newly purchased DC IN 6V adapter and wires in their original place.
    • Using a soldering iron and soldering wire, reattach the black wire from the battery case (above DC IN 6V chip) to the bottom of the DC IN 6V chip.
    • Using the soldering iron soldering wire, reattach the red and black wire from the motherboard (on the left of the DC IN 6V chip) in that respective order above the previously soldered black wire.
    • Use the soldering iron and soldering wire one last time to reattach the blue wire above the soldered black wire from the motherboard.
결론
Cristina Garcia
회원 가입일: 10/13/14
301 평판
안내서 3개 작성하였습니다
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014 회원
CLEM-BENSON-F14S3G4
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 347
