필요한 것
Use your fingers to slide the battery case cover off in the direction of the arrows.
Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
Unscrew the 0.6 mm screw located in the center of the battery case.
Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
Remove the back cover carefully; there are many wires that connect it to the device.
Position the portable speaker device so that the back cover and the speaker are both laying flat, giving you access to the inside of the device
If the motherboard is at the bottom when you are looking down at the device, the LINE IN adapter should be on the left side of the back cover
Carefully remove the LINE IN adapter using a pair of tweezers
Remove the black and red wires attached to the LINE IN adapter that extend from the motherboard by cutting them with scissors
Repeat previous step for the blue and second black wire connecting the adapter to the battery case.
At this point, you should be able to carefully remove the entire faulty adapter and the wires.
Position the newly purchased LINE IN adapter and wires in place
Using a soldering iron and soldering wire, reattach the red and black wires that extend from the motherboard to their original position on the LINE IN adapter
Use the soldering iron and soldering wire again to reattach the black and blue wires that extend from the battery case to their original position on the LINE IN adapter
The blue wire should attach on the bottom of the battery case and the black wire on the top insertion.
The new LINE IN adapter should now be properly assembled in place with the wires connected to their proper location.
