주요 콘텐츠로 건너뛰기
iHip Fold-up Portable Speaker Motherboard Replacement
필요한 것
  1. iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Place the device on a flat surface as shown.
    • Remove the battery case cover and batteries.
  2. iHip Fold-up Portable Speaker Motherboard Replacement: 2 단계, 이미지 1/3 iHip Fold-up Portable Speaker Motherboard Replacement: 2 단계, 이미지 2/3 iHip Fold-up Portable Speaker Motherboard Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a Phillips-Head #1 screwdriver, unscrew the four outer 1.0 mm screws and remove with tweezers.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Remove the back cover carefully; there are many wires that connect it to the device.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  3. iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: 3 단계, 이미지 1/2 iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: 3 단계, 이미지 2/2
    • Observe the location of the motherboard at the bottom center of the back cover.
    • Using a Phillips-Head #1 screwdriver, carefully unscrew all three 0.4 mm screws from the indicated locations. Set aside for reassembly.
    • Using tweezers, gently remove the motherboard from the back cover of the device.
  4. iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: 4 단계, 이미지 1/2 iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: 4 단계, 이미지 2/2
    • Note the connection point of each wire to the motherboard.
    • Using utility scissors, cut all the wires connecting the motherboard to the device.
    • Using tweezers, place the new motherboard in the exact position of the old motherboard.
  5. iHip Fold-up Portable Speaker Motherboard Replacement, Soldering the Wires: 5 단계, 이미지 1/1
    • Read the manufacturer instructions for your specific soldering iron before use. Follow all safety instructions and solder at your own risk.
    • Position a strip of solder at the point of contact between the motherboard and each individual wire.
    • Solder the wires to the motherboard. Make sure to follow the manufacturer's instructions, as well as general soldering safety principles.
  6. iHip Fold-up Portable Speaker Motherboard Replacement, Securing the New Motherboard: 6 단계, 이미지 1/1
    • Using a Phillips-Head #1 screwdriver, screw the original 0.4 mm screws into the correct places to secure the motherboard back in place.
결론
Amanda
회원 가입일: 10/13/14
201 평판
안내서 2개 작성하였습니다
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014 회원
CLEM-BENSON-F14S3G4
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 627
