주요 콘텐츠로 건너뛰기
iHome iAVS16 Motherboard Replacement
필요한 것
  1. iHome iAVS16 Motherboard Replacement, Power Board: 1 단계, 이미지 1/3 iHome iAVS16 Motherboard Replacement, Power Board: 1 단계, 이미지 2/3 iHome iAVS16 Motherboard Replacement, Power Board: 1 단계, 이미지 3/3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Motherboard Replacement: 2 단계, 이미지 1/3 iHome iAVS16 Motherboard Replacement: 2 단계, 이미지 2/3 iHome iAVS16 Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Motherboard Replacement: 3 단계, 이미지 1/2 iHome iAVS16 Motherboard Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Motherboard Replacement: 4 단계, 이미지 1/3 iHome iAVS16 Motherboard Replacement: 4 단계, 이미지 2/3 iHome iAVS16 Motherboard Replacement: 4 단계, 이미지 3/3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 Motherboard Replacement, LCD (Display): 5 단계, 이미지 1/3 iHome iAVS16 Motherboard Replacement, LCD (Display): 5 단계, 이미지 2/3 iHome iAVS16 Motherboard Replacement, LCD (Display): 5 단계, 이미지 3/3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 Motherboard Replacement: 7 단계, 이미지 1/3 iHome iAVS16 Motherboard Replacement: 7 단계, 이미지 2/3 iHome iAVS16 Motherboard Replacement: 7 단계, 이미지 3/3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
  8. iHome iAVS16 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • Flip up the back of the device encasing the motherboard.
  9. iHome iAVS16 Motherboard Replacement: 9 단계, 이미지 1/3 iHome iAVS16 Motherboard Replacement: 9 단계, 이미지 2/3 iHome iAVS16 Motherboard Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, unplug the white, red, and blue connectors from the motherboard by pulling each out.
  10. iHome iAVS16 Motherboard Replacement: 10 단계, 이미지 1/1
    • Carefully unplug the ribbon cable, making sure not to rip it.
결론
James Hoye
회원 가입일: 10/25/19
97 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 227
