주요 콘텐츠로 건너뛰기
iHome iAVS16 Power Board Replacement
필요한 것
  1. iHome iAVS16 Power Board Replacement, Power Board: 1 단계, 이미지 1/3 iHome iAVS16 Power Board Replacement, Power Board: 1 단계, 이미지 2/3 iHome iAVS16 Power Board Replacement, Power Board: 1 단계, 이미지 3/3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Power Board Replacement: 2 단계, 이미지 1/3 iHome iAVS16 Power Board Replacement: 2 단계, 이미지 2/3 iHome iAVS16 Power Board Replacement: 2 단계, 이미지 3/3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Power Board Replacement: 3 단계, 이미지 1/2 iHome iAVS16 Power Board Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Power Board Replacement: 4 단계, 이미지 1/3 iHome iAVS16 Power Board Replacement: 4 단계, 이미지 2/3 iHome iAVS16 Power Board Replacement: 4 단계, 이미지 3/3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
결론
Ashley Famularo
회원 가입일: 10/25/19
181 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 123
