주요 콘텐츠로 건너뛰기
iHome iBT16 Base Plate Replacement
필요한 것
  1. iHome iBT16 Base Plate Replacement, Base Plate: 1 단계, 이미지 1/2 iHome iBT16 Base Plate Replacement, Base Plate: 1 단계, 이미지 2/2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Base Plate Replacement: 2 단계, 이미지 1/2 iHome iBT16 Base Plate Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
결론
Ryan Edwards
회원 가입일: 03/21/17
331 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G6
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 16
전체 시간: 229
