주요 콘텐츠로 건너뛰기
iHome iBT16 Motherboard Replacement
필요한 것
  1. iHome iBT16 Motherboard Replacement, Base Plate: 1 단계, 이미지 1/2 iHome iBT16 Motherboard Replacement, Base Plate: 1 단계, 이미지 2/2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: 2 단계, 이미지 1/2 iHome iBT16 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 iHome iBT16 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 iHome iBT16 Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: 4 단계, 이미지 1/2 iHome iBT16 Motherboard Replacement: 4 단계, 이미지 2/2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the plastic cover from the power switch actuator on the motherboard.
결론
Joseph Hazel
회원 가입일: 03/24/17
329 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 UMass Dartmouth, Team S8-G4, Valliere Spring 2018 회원
UMASSD-VALLIERE-S18S8G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 1,137
