주요 콘텐츠로 건너뛰기
iHome iBT230 Keyboard (Buttons) Replacement
필요한 것
  1. iHome iBT230 Keyboard (Buttons) Replacement, Keyboard (Buttons): 1 단계, 이미지 1/1
    • Remove the four 5.5 mm Phillips Head #00 screws from the bottom palate of the iBT230.
  2. iHome iBT230 Keyboard (Buttons) Replacement: 2 단계, 이미지 1/2 iHome iBT230 Keyboard (Buttons) Replacement: 2 단계, 이미지 2/2
    • Grip the top of the iBT230 by placing your thumb on the back portion, where the USB port is located. Pull up, and you should notice various different colored wires, connected to the Main Motherboard.
  3. iHome iBT230 Keyboard (Buttons) Replacement: 3 단계, 이미지 1/2 iHome iBT230 Keyboard (Buttons) Replacement: 3 단계, 이미지 2/2
    • Unplug the connectors from all sides of the iBT230, and unplug the wire connected to the screen.
    • Make sure to note which wire goes where, you don't want to re-solder the wires into the incorrect ports!
  4. iHome iBT230 Keyboard (Buttons) Replacement: 4 단계, 이미지 1/1
    • Unscrew the four 5.5 mm Phillips #00 face panel screws from the front screen.
  5. iHome iBT230 Keyboard (Buttons) Replacement: 5 단계, 이미지 1/2 iHome iBT230 Keyboard (Buttons) Replacement: 5 단계, 이미지 2/2
    • Once the four 5.5 mm Phillips #00 screws come out, slide the screen out vertically.
    • Disconnect the blue tipped ribbon from the back of the screen.
  6. iHome iBT230 Keyboard (Buttons) Replacement: 6 단계, 이미지 1/2 iHome iBT230 Keyboard (Buttons) Replacement: 6 단계, 이미지 2/2
    • Once the screen is removed, unscrew the six 4.0 mm Phillips #02 screws located on top of the keyboard.
    • As shown in the image, the keyboard is represented by a brown colored palate.
  7. iHome iBT230 Keyboard (Buttons) Replacement: 7 단계, 이미지 1/1
    • Disconnect the blue tipped ribbon from the back of the keyboard.
결론
Bilal Siddiqui
회원 가입일: 04/10/17
376 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S3-G6, Liner Spring 2017 UW Tacoma, Team S3-G6, Liner Spring 2017 회원
UWT-LINER-S17S3G6
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 343
