주요 콘텐츠로 건너뛰기
iHome iBT84 Light Fixture Replacement
필요한 것
  1. iHome iBT84 Light Fixture Replacement, Motherboard: 1 단계, 이미지 1/2 iHome iBT84 Light Fixture Replacement, Motherboard: 1 단계, 이미지 2/2
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Light Fixture Replacement: 2 단계, 이미지 1/2 iHome iBT84 Light Fixture Replacement: 2 단계, 이미지 2/2
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Light Fixture Replacement: 3 단계, 이미지 1/3 iHome iBT84 Light Fixture Replacement: 3 단계, 이미지 2/3 iHome iBT84 Light Fixture Replacement: 3 단계, 이미지 3/3
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Light Fixture Replacement: 4 단계, 이미지 1/1
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
  5. iHome iBT84 Light Fixture Replacement, Light Fixture: 5 단계, 이미지 1/1
    • Use the screwdriver to unscrew the screws on the left and right sides.
  6. iHome iBT84 Light Fixture Replacement: 6 단계, 이미지 1/1
    • Once unscrewed, use the metal spudge to lift the base of the light fixture.
  7. iHome iBT84 Light Fixture Replacement: 7 단계, 이미지 1/2 iHome iBT84 Light Fixture Replacement: 7 단계, 이미지 2/2
    • Lift the base of the light fixture out with the lights.
    • Be careful. The light fixture's can be easily bent.
  8. iHome iBT84 Light Fixture Replacement: 8 단계, 이미지 1/2 iHome iBT84 Light Fixture Replacement: 8 단계, 이미지 2/2
    • Pull gently on the individual light fixture that needs to be replaced.
    • Place new individual LED light strip.
결론
Joshua Lopez
회원 가입일: 09/25/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 569
