이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
Use a Philip's screwdriver to take the screws out of the cover.
Once the screws are all out, the cover should come off revealing the motherboard.
You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
Once that is done, the motherboard can be taken out. May require some wiggling.
Make sure none of the wires are damaged and that they are all connected.
The connections shown here can be taken off by pulling on the white plastic connector piece.
The same can be said about the white, paper like, connectors. Pull on them gently.
Once all connections are apart, the motherboard is safe to be replaced.
Once unscrewed, use the metal spudge to lift the base of the light fixture.
Lift the base of the light fixture out with the lights.
Be careful. The light fixture's can be easily bent.
Pull gently on the individual light fixture that needs to be replaced.
Place new individual LED light strip.
