주요 콘텐츠로 건너뛰기
iHome iD95 Screen Cover Replacement
필요한 것
  1. iHome iD95 Screen Cover Replacement, Backup Battery: 1 단계, 이미지 1/1
    • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
    • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
  2. iHome iD95 Screen Cover Replacement: 2 단계, 이미지 1/1
    • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
  3. iHome iD95 Screen Cover Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to take out the backup battery.
  4. iHome iD95 Screen Cover Replacement, Bottom Cover: 4 단계, 이미지 1/1
    • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
  5. iHome iD95 Screen Cover Replacement: 5 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 5 단계, 이미지 2/2
    • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
    • Insert a plastic opening tool between the edge of the bottom cover and the main body.
    • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
    • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
  6. iHome iD95 Screen Cover Replacement: 6 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 6 단계, 이미지 2/2
    • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
    • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
    • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
  7. iHome iD95 Screen Cover Replacement: 7 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 7 단계, 이미지 2/2
    • Apply the same techniques from the previous step to remove the remaining side panel.
  8. iHome iD95 Screen Cover Replacement: 8 단계, 이미지 1/3 iHome iD95 Screen Cover Replacement: 8 단계, 이미지 2/3 iHome iD95 Screen Cover Replacement: 8 단계, 이미지 3/3
    • Locate the two plastic clips holding the bottom and back cover together.
    • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
    • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
    • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
    • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
  9. iHome iD95 Screen Cover Replacement: 9 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 9 단계, 이미지 2/2
    • Use the same steps to remove the remaining clip.
    • The bottom cover is still connected to the motherboard by wiring.
  10. iHome iD95 Screen Cover Replacement: 10 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 10 단계, 이미지 2/2
    • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
    • Don't pull the wires. Take your time using a plastic opening tool.
  11. iHome iD95 Screen Cover Replacement, Speakers: 11 단계, 이미지 1/1
    • Take out four 14 mm screws using a Phillips #1 screwdriver.
  12. iHome iD95 Screen Cover Replacement: 12 단계, 이미지 1/3 iHome iD95 Screen Cover Replacement: 12 단계, 이미지 2/3 iHome iD95 Screen Cover Replacement: 12 단계, 이미지 3/3
    • Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
    • Do not pull on the speaker wires directly. Continue to use a plastic opening tool.
  13. iHome iD95 Screen Cover Replacement: 13 단계, 이미지 1/1
    • Lift and remove both speakers.
  14. iHome iD95 Screen Cover Replacement, Screen Cover: 14 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement, Screen Cover: 14 단계, 이미지 2/2
    • Flip the logic board over.
    • Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
  15. iHome iD95 Screen Cover Replacement: 15 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 15 단계, 이미지 2/2
    • Use a plastic opening tool to pry and lift up the white zip connector holding the LCD screen to the buttons.
  16. iHome iD95 Screen Cover Replacement: 16 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 16 단계, 이미지 2/2
    • Gently push the screen away from you to dislodge it from the plastic clip holding it in place and then pull up to remove.
  17. iHome iD95 Screen Cover Replacement: 17 단계, 이미지 1/2 iHome iD95 Screen Cover Replacement: 17 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to unscrew three, 9.5 mm-length 4 mm-head, screws holding the LCD screen to the screen cover.
    • Remove the screen cover from the LCD.
결론
Vincent Chan
회원 가입일: 04/18/13
19 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-37, Amido Spring 2013 Cal Poly, Team 12-37, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G37
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 1,537
