주요 콘텐츠로 건너뛰기
iHome iH27B Daylight Savings Switch Replacement
필요한 것
  1. iHome iH27B Daylight Savings Switch Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Daylight Savings Switch Replacement: 2 단계, 이미지 1/3 iHome iH27B Daylight Savings Switch Replacement: 2 단계, 이미지 2/3 iHome iH27B Daylight Savings Switch Replacement: 2 단계, 이미지 3/3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Daylight Savings Switch Replacement: 3 단계, 이미지 1/1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Daylight Savings Switch Replacement: 4 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Daylight Savings Switch Replacement: 5 단계, 이미지 1/1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Daylight Savings Switch Replacement, Daylight Savings Switch: 6 단계, 이미지 1/1
    • Two 10 mm Phillips #0
  7. iHome iH27B Daylight Savings Switch Replacement: 7 단계, 이미지 1/1
    • Remove switch and replace with new one.
결론
John Kraemer
회원 가입일: 10/09/12
76 평판
안내서 9개 작성하였습니다
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G21
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 709
