주요 콘텐츠로 건너뛰기
iHome iH27B Right Control Button Replacement
필요한 것
  1. iHome iH27B Right Control Button Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Right Control Button Replacement: 2 단계, 이미지 1/3 iHome iH27B Right Control Button Replacement: 2 단계, 이미지 2/3 iHome iH27B Right Control Button Replacement: 2 단계, 이미지 3/3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Right Control Button Replacement: 3 단계, 이미지 1/1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Right Control Button Replacement: 4 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Right Control Button Replacement: 5 단계, 이미지 1/1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Right Control Button Replacement, AV circuit board: 6 단계, 이미지 1/1
    • Two 10 mm Phillips #0
  7. iHome iH27B Right Control Button Replacement: 7 단계, 이미지 1/1
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
  8. iHome iH27B Right Control Button Replacement, Main Motherboard: 8 단계, 이미지 1/1
    • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
  9. iHome iH27B Right Control Button Replacement: 9 단계, 이미지 1/1
    • Remove the following 6 screws:
    • Two 7 mm Phillips #0
    • Three 10 mm Phillips #2
    • One 9 mm Phillips #2
    • Set the screws aside, careful to not mix them up with your other screws.
  10. iHome iH27B Right Control Button Replacement, Right Control Button: 10 단계, 이미지 1/1
    • Remember that the device is still upside down, so the right control button will be on the left side. Then rotate the device so it looks as it does in the picture. Peek to verify you are going to the correct spot, because the iHome looks symmetrical at this point.
    • Carefully lift the main motherboard out of the way of the button control circuit board.
    • Four 6 mm Phillips head screws
  11. iHome iH27B Right Control Button Replacement: 11 단계, 이미지 1/1
    • Pull the button control motherboard up and out of the way.
    • Use a Flathead screwdriver to push on each of the button tabs.
    • Push the button away and out.
  12. iHome iH27B Right Control Button Replacement: 12 단계, 이미지 1/1
    • Replace broken button with new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Kraemer
회원 가입일: 10/09/12
76 평판
안내서 9개 작성하였습니다
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G21
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
My volume decrease button was not working. I disassembled per these instructions, blew out the device with compressed air and then contact cleaner and reassembled per the reverse instructions. The screws in step 9 were slightly different (the same holes were there, but the presence/absence of screws was slightly different). I am now happily listening to my iHome right now. Thank you for posting this!!!
Brandy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 813
