주요 콘텐츠로 건너뛰기
iHome iH5 Charging Dock Replacement
필요한 것
  1. iHome iH5 Charging Dock Replacement, Charging Dock: 1 단계, 이미지 1/1
    • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  2. iHome iH5 Charging Dock Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  3. iHome iH5 Charging Dock Replacement: 3 단계, 이미지 1/1
    • Remove the five 5/16 inch screws from the circuit board.
  4. iHome iH5 Charging Dock Replacement: 4 단계, 이미지 1/2 iHome iH5 Charging Dock Replacement: 4 단계, 이미지 2/2
    • Flip the circuit board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
  5. iHome iH5 Charging Dock Replacement: 5 단계, 이미지 1/1
    • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
  6. iHome iH5 Charging Dock Replacement: 6 단계, 이미지 1/1
    • Gently remove the charging dock from the iHome iH5 by pulling it up.
  7. iHome iH5 Charging Dock Replacement: 7 단계, 이미지 1/1
    • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
  8. iHome iH5 Charging Dock Replacement: 8 단계, 이미지 1/1
    • Replace the old iH5 charging dock with new iH5 charging dock.
결론
Dustin Lamb
회원 가입일: 03/13/14
103 평판
안내서 1개 작성함
New Mexico State, Team 1-6, Easley Spring 2014 New Mexico State, Team 1-6, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G6
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 979
