주요 콘텐츠로 건너뛰기
iHome iH5 Dials Replacement
필요한 것
  1. iHome iH5 Dials Replacement, Dials: 1 단계, 이미지 1/1
    • Remove the eight screws from the bottom side of the iHome.
  2. iHome iH5 Dials Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the cover to expose the inside.
    • With pliers, or tweezers,if needed, remove the three wire harnesses by gently pulling straight up on them.
  3. iHome iH5 Dials Replacement: 3 단계, 이미지 1/1
    • Remove the 5 screws with a #2 Phillips screwdriver.
  4. iHome iH5 Dials Replacement: 4 단계, 이미지 1/1
    • Remove all wire harnesses from the bottom of the board. There eight wire harnesses.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  5. iHome iH5 Dials Replacement: 5 단계, 이미지 1/3 iHome iH5 Dials Replacement: 5 단계, 이미지 2/3 iHome iH5 Dials Replacement: 5 단계, 이미지 3/3
    • Remove the two screws from the speakers with a #2 Phillips screwdriver.
    • Turn the device on its front side and remove the two screws with a #2 Phillips screwdriver.
    • Pull the speaker up from the back as shown with the speaker on the right. Then pull the speaker straight back as shown with the speaker on the left.
  6. iHome iH5 Dials Replacement: 6 단계, 이미지 1/1
    • Remove the front piece by pulling up until it hits the plastic pieces sticking out from the display screen. Then pull it out horizontally from the device.
  7. iHome iH5 Dials Replacement: 7 단계, 이미지 1/1
    • Remove the three screw from the dial with a #2 Phillips screwdriver.
  8. iHome iH5 Dials Replacement: 8 단계, 이미지 1/1
    • Pull back the circuit board to access the plastic piece.
    • Lift to separate the plastic piece from the dial.
    • Replace the broken piece.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maggie Hill
회원 가입일: 03/20/14
379 평판
안내서 3개 작성하였습니다
New Mexico State, Team 1-6, Easley Spring 2014 New Mexico State, Team 1-6, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G6
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,046
