이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the cover to expose the inside.
With pliers, or tweezers,if needed, remove the three wire harnesses by gently pulling straight up on them.
Remove all wire harnesses from the bottom of the board. There eight wire harnesses.
Remove the two screws from the speakers with a #2 Phillips screwdriver.
Turn the device on its front side and remove the two screws with a #2 Phillips screwdriver.
Pull the speaker up from the back as shown with the speaker on the right. Then pull the speaker straight back as shown with the speaker on the left.
Remove the front piece by pulling up until it hits the plastic pieces sticking out from the display screen. Then pull it out horizontally from the device.
Pull back the circuit board to access the plastic piece.
Lift to separate the plastic piece from the dial.
Replace the broken piece.
다른 3명이 해당 안내서를 완성하였습니다.
