주요 콘텐츠로 건너뛰기
iHome iH5 Speakers Replacement
필요한 것
  1. iHome iH5 Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Unscrew the bottom of the iHome at the marked points with a #2 phillips
  2. iHome iH5 Speakers Replacement: 2 단계, 이미지 1/1
    • Remove wires from the logic board (tweezers or pliers are helpful)
  3. iHome iH5 Speakers Replacement: 3 단계, 이미지 1/1
    • Unscrew at the marked points with #2 Phillips screwdriver.
  4. iHome iH5 Speakers Replacement: 4 단계, 이미지 1/2 iHome iH5 Speakers Replacement: 4 단계, 이미지 2/2
    • Flip the board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires for the board with tweezers. If they're tight pliers can be used instead.
    • There is one in the orange box.
    • There are two in the yellow box.
    • The are five in the green box.
  5. iHome iH5 Speakers Replacement: 5 단계, 이미지 1/3 iHome iH5 Speakers Replacement: 5 단계, 이미지 2/3 iHome iH5 Speakers Replacement: 5 단계, 이미지 3/3
    • Remove the two screws with a #2 Phillips screwdriver.
    • Flip the device on its front then remove the two screws with a #2 Phillips screwdriver.
    • Grab the speaker and pull it up until it looks like the speaker on the right. Then pull is straight back like shown with the speaker on the left.
  6. iHome iH5 Speakers Replacement: 6 단계, 이미지 1/1
    • Remove the four screws with a #2 Phillips screwdriver.
    • Replace the broken speaker.
결론
Maggie Hill
회원 가입일: 03/20/14
379 평판
안내서 3개 작성하였습니다
New Mexico State, Team 1-6, Easley Spring 2014 New Mexico State, Team 1-6, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G6
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 685
