이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unscrew the bottom of the iHome at the marked points with a #2 phillips
Flip the board over.
Unplug the eight wires for the board with tweezers. If they're tight pliers can be used instead.
There is one in the orange box.
There are two in the yellow box.
The are five in the green box.
Remove the two screws with a #2 Phillips screwdriver.
Flip the device on its front then remove the two screws with a #2 Phillips screwdriver.
Grab the speaker and pull it up until it looks like the speaker on the right. Then pull is straight back like shown with the speaker on the left.
Remove the four screws with a #2 Phillips screwdriver.
Replace the broken speaker.
