주요 콘텐츠로 건너뛰기
iHome iH8BR Lower Case Replacement
필요한 것
  1. iHome iH8BR Lower Case Replacement, Lower Case: 1 단계, 이미지 1/3 iHome iH8BR Lower Case Replacement, Lower Case: 1 단계, 이미지 2/3 iHome iH8BR Lower Case Replacement, Lower Case: 1 단계, 이미지 3/3
    • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
    • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
    • Remove the battery cover and the batteries.
  2. iHome iH8BR Lower Case Replacement: 2 단계, 이미지 1/2 iHome iH8BR Lower Case Replacement: 2 단계, 이미지 2/2
    • Slide a spudger under the two front rubber pads to expose two hidden screws.
  3. iHome iH8BR Lower Case Replacement: 3 단계, 이미지 1/1
    • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
  4. iHome iH8BR Lower Case Replacement: 4 단계, 이미지 1/2 iHome iH8BR Lower Case Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
    • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
    • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
    • The lower case can now be completely removed from the device!
결론
cfredric
회원 가입일: 04/17/13
25 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-33, Amido Spring 2013 Cal Poly, Team 12-33, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G33
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 555
