주요 콘텐츠로 건너뛰기
iHome iM71SC Spring Replacement
필요한 것
  1. iHome iM71SC Spring Replacement, iHome iM71SC Disassembly: 1 단계, 이미지 1/1
    • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
  2. iHome iM71SC Spring Replacement: 2 단계, 이미지 1/1
    • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
  3. iHome iM71SC Spring Replacement: 3 단계, 이미지 1/1
    • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
  4. iHome iM71SC Spring Replacement: 4 단계, 이미지 1/1
    • Remove the now unfastened coverings to expose the internals of the speaker.
  5. iHome iM71SC Spring Replacement, Spring: 5 단계, 이미지 1/1
    • Pry the spring from the speaker housing using the blue plastic pry tool.
  6. iHome iM71SC Spring Replacement: 6 단계, 이미지 1/2 iHome iM71SC Spring Replacement: 6 단계, 이미지 2/2
    • Unwind the old spring from the wires.
결론
Sarah Brown
회원 가입일: 03/21/17
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S7-G5, Julie Spring 2017 UMass Dartmouth, Team S7-G5, Julie Spring 2017 회원
UMASSD-JULIE-S17S7G5
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 122
