주요 콘텐츠로 건너뛰기
iHome iP1 30-pin Connector Replacement
필요한 것
  1. iHome iP1 30-pin Connector Replacement, Dock Cover: 1 단계, 이미지 1/1
    • Orient the iHome upside down with the speakers facing you.
  2. iHome iP1 30-pin Connector Replacement: 2 단계, 이미지 1/1
    • Remove the two 9.5 mm Phillips #1 screws from the dock cover.
  3. iHome iP1 30-pin Connector Replacement: 3 단계, 이미지 1/3 iHome iP1 30-pin Connector Replacement: 3 단계, 이미지 2/3 iHome iP1 30-pin Connector Replacement: 3 단계, 이미지 3/3
    • Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
  4. iHome iP1 30-pin Connector Replacement, Back Cover: 4 단계, 이미지 1/1
    • Orient the iHome upside down with the speakers facing away from you.
  5. iHome iP1 30-pin Connector Replacement: 5 단계, 이미지 1/2 iHome iP1 30-pin Connector Replacement: 5 단계, 이미지 2/2
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  6. iHome iP1 30-pin Connector Replacement: 6 단계, 이미지 1/1
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  7. iHome iP1 30-pin Connector Replacement, 30-pin Connector: 7 단계, 이미지 1/1
    • Rotate the iHome so that the speakers are facing you.
    • Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
  8. iHome iP1 30-pin Connector Replacement: 8 단계, 이미지 1/3 iHome iP1 30-pin Connector Replacement: 8 단계, 이미지 2/3 iHome iP1 30-pin Connector Replacement: 8 단계, 이미지 3/3
    • Rotate the iHome so that the speakers are once again facing away from you and the motherboard is still exposed.
    • Unplug the wide red/white/black wire bundle from the lower right-hand corner of the motherboard by pulling it out of their connection.
  9. iHome iP1 30-pin Connector Replacement: 9 단계, 이미지 1/3 iHome iP1 30-pin Connector Replacement: 9 단계, 이미지 2/3 iHome iP1 30-pin Connector Replacement: 9 단계, 이미지 3/3
    • Rotate the iHome iP1 so that the speakers are now facing you.
    • Remove both of the speaker covers by pulling them off of the faceplate.
  10. iHome iP1 30-pin Connector Replacement: 10 단계, 이미지 1/1
    • Unscrew the twelve 14.5 mm Phillips #2 screws holding the faceplate to the speaker housing. (There are six screws connecting the faceplate to each speaker.)
    • Completing this step will loosen the faceplate enough to pull the bundle of cables attached to the 30-pin connector through a hole in the faceplate, allowing the 30-pin connector to be removed from the iHome.
  11. iHome iP1 30-pin Connector Replacement: 11 단계, 이미지 1/3 iHome iP1 30-pin Connector Replacement: 11 단계, 이미지 2/3 iHome iP1 30-pin Connector Replacement: 11 단계, 이미지 3/3
    • Detach the 30-pin connector from the dock housing by pushing it through the slot which it sticks out of.
    • Sometimes the 30-pin connector can get stuck in the dock housing, making it difficult to push through. To prevent this, push each side of the 30-pin connector evenly. This step can be accomplished without the use of any additional tools.
    • The command buttons have been shown as removed to show how to detach the 30-pin connector. However, it is not necessary to remove the command buttons in order to remove the 30-pin connector.
  12. iHome iP1 30-pin Connector Replacement: 12 단계, 이미지 1/3 iHome iP1 30-pin Connector Replacement: 12 단계, 이미지 2/3 iHome iP1 30-pin Connector Replacement: 12 단계, 이미지 3/3
    • Remove the 30-pin connector from the iHome by pulling the bundle of cables attached to it through the center hole in the faceplate.
    • You may have to wiggle the faceplate to be able to pull the bundle of cables through its center hole.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Wen Sullivan
회원 가입일: 10/06/16
518 평판
안내서 4개 작성하였습니다
Cal Poly, Team 20-1, Livingston Fall 2016 Cal Poly, Team 20-1, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G1
4 회원들
안내서 7개 작성하였습니다
댓글 4개
Where can you buy a new pin connector?
shoreman19 - 답글
Where can I buy a new pin connector?
shoreman19 - 답글
Edward Voermans - 답글
where can i buy new Board
Riyu PC - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 2,479
