소개
Use this guide to replace your iHome iP1's damaged or faulty 30-pin connector. This connector is located on the iPod/iPhone dock and is used to connect your Apple device to your iHome iP1.
필요한 것
Rotate the iHome so that the speakers are facing you.
Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
Where can you buy a new pin connector?
shoreman19 - 답글
Where can I buy a new pin connector?
shoreman19 - 답글
