주요 콘텐츠로 건너뛰기
iHome iP21 Motherboard Replacement
필요한 것
  1. iHome iP21 Motherboard Replacement, Base: 1 단계, 이미지 1/3 iHome iP21 Motherboard Replacement, Base: 1 단계, 이미지 2/3 iHome iP21 Motherboard Replacement, Base: 1 단계, 이미지 3/3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Motherboard Replacement, Housing: 2 단계, 이미지 1/2 iHome iP21 Motherboard Replacement, Housing: 2 단계, 이미지 2/2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Motherboard Replacement, Circuit board: 3 단계, 이미지 1/1
    • Follow the prerequisite guide to remove the main housing.
  4. iHome iP21 Motherboard Replacement, Circuit board mount: 4 단계, 이미지 1/1
    • Remove the two 7mm screws from the circuit board
  5. iHome iP21 Motherboard Replacement, Mounting Bracket: 5 단계, 이미지 1/1
    • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
  6. iHome iP21 Motherboard Replacement, Cables: 6 단계, 이미지 1/3 iHome iP21 Motherboard Replacement, Cables: 6 단계, 이미지 2/3 iHome iP21 Motherboard Replacement, Cables: 6 단계, 이미지 3/3
    • Peel the glue from each of the three ribbon cable connections.
    • Remove the solder joints from the back of each ribbon cable.
    • Remove the ground wires by removing the solder joints on the back of the housing.
  7. iHome iP21 Motherboard Replacement, Detach cables from circuit board: 7 단계, 이미지 1/3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: 7 단계, 이미지 2/3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: 7 단계, 이미지 3/3
    • Remove glue from 3 ribbon cables from circuit board using fingers
    • Detach speaker cables from circuit board with soldering iron
    • Remove 3 ribbon cables with soldering iron
결론
Brandy
회원 가입일: 10/27/14
601 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 12
전체 시간: 274
