주요 콘텐츠로 건너뛰기
iHome iP21 Speaker Replacement
필요한 것
  1. iHome iP21 Speaker Replacement, Base: 1 단계, 이미지 1/3 iHome iP21 Speaker Replacement, Base: 1 단계, 이미지 2/3 iHome iP21 Speaker Replacement, Base: 1 단계, 이미지 3/3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Speaker Replacement, Housing: 2 단계, 이미지 1/2 iHome iP21 Speaker Replacement, Housing: 2 단계, 이미지 2/2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Speaker Replacement, Remove Speaker Assembly: 3 단계, 이미지 1/1
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  4. iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: 4 단계, 이미지 1/2 iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: 4 단계, 이미지 2/2
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
결론
Brandy
회원 가입일: 10/27/14
601 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 203
