소개
This guide instructs you to replace the battery in an iHome iPL8. The process includes using screwdriver and removing bottom door of the device to detach the battery.
필요한 것
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
