주요 콘텐츠로 건너뛰기
iHome iPL8 Lightning Connector Replacement
필요한 것
  1. iHome iPL8 Lightning Connector Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
  2. iHome iPL8 Lightning Connector Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
  3. iHome iPL8 Lightning Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
  4. iHome iPL8 Lightning Connector Replacement: 4 단계, 이미지 2개 중 1개 iHome iPL8 Lightning Connector Replacement: 4 단계, 이미지 2개 중 2개
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
  5. iHome iPL8 Lightning Connector Replacement, Lightning Connector: 5 단계, 이미지 1개 중 1개
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
  6. iHome iPL8 Lightning Connector Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
  7. iHome iPL8 Lightning Connector Replacement: 7 단계, 이미지 2개 중 1개 iHome iPL8 Lightning Connector Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
  8. iHome iPL8 Lightning Connector Replacement: 8 단계, 이미지 2개 중 1개 iHome iPL8 Lightning Connector Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
  9. iHome iPL8 Lightning Connector Replacement: 9 단계, 이미지 3개 중 1개 iHome iPL8 Lightning Connector Replacement: 9 단계, 이미지 3개 중 2개 iHome iPL8 Lightning Connector Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
결론
작성자
1다른 기여자 명과 함께
Chen Zhong
회원 가입일: 02/05/19
569 평판
안내서 4개를 작성함
UC Davis, Team S18-G5, Lore Winter 2019 UC Davis, Team S18-G5, Lore Winter 2019 회원
UCD-LORE-W19S18G5
3 회원들
안내서 4개를 작성함
3가이드 댓글
where can I find the replacement lightning connector?
Bond 007 and a Half - 답글
Greetings, did you ever find the connector replacement? I am asking so that I can purchase. Thank you in advance for your reply.
Shawn Simmons -
I’m trying to find the replacement part to buy too.
Wendy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 836
