주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iHome iPL8 Screen Replacement
필요한 것
  1. iHome iPL8 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
    댓글 쓰기
  2. iHome iPL8 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
    댓글 쓰기
  3. iHome iPL8 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
    댓글 쓰기
  4. iHome iPL8 Screen Replacement: 4 단계, 이미지 2개 중 1개 iHome iPL8 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
    댓글 쓰기
  5. iHome iPL8 Screen Replacement, Lightning Connector: 5 단계, 이미지 1개 중 1개
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
    댓글 쓰기
  6. iHome iPL8 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
    댓글 쓰기
  7. iHome iPL8 Screen Replacement: 7 단계, 이미지 2개 중 1개 iHome iPL8 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
    댓글 쓰기
  8. iHome iPL8 Screen Replacement: 8 단계, 이미지 2개 중 1개 iHome iPL8 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
    댓글 쓰기
  9. iHome iPL8 Screen Replacement: 9 단계, 이미지 3개 중 1개 iHome iPL8 Screen Replacement: 9 단계, 이미지 3개 중 2개 iHome iPL8 Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
    댓글 쓰기
  10. iHome iPL8 Screen Replacement, Screen: 10 단계, 이미지 1개 중 1개
    • Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
    • Remove the four 2.5 mm Phillips #1 screws on the green panel.
    • Flip the green panel to reveal the front of the screen.
    댓글 쓰기
  11. iHome iPL8 Screen Replacement: 11 단계, 이미지 2개 중 1개 iHome iPL8 Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Locate the transparent, rectangular plastic screen cover.
    • Gently lift the cover off.
    • The screen is now revealed. Replace the screen with a functioning one.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chen Zhong
회원 가입일: 02/05/19
569 평판
안내서 4개를 작성함
UC Davis, Team S18-G5, Lore Winter 2019 UC Davis, Team S18-G5, Lore Winter 2019 회원
UCD-LORE-W19S18G5
3 회원들
안내서 8개를 작성함
1가이드 댓글
Hi, I have one iHome iBN20 that needs to replace the screen too.
Please guide me to open up the casing.
Thank you.
Chan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 436
