주요 콘텐츠로 건너뛰기
iLive IKBC384S Audio Speakers Replacement
필요한 것
  1. iLive IKBC384S Audio Speakers Replacement, Top Cover: 1 단계, 이미지 1/2 iLive IKBC384S Audio Speakers Replacement, Top Cover: 1 단계, 이미지 2/2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Audio Speakers Replacement: 2 단계, 이미지 1/2 iLive IKBC384S Audio Speakers Replacement: 2 단계, 이미지 2/2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Audio Speakers Replacement: 3 단계, 이미지 1/2 iLive IKBC384S Audio Speakers Replacement: 3 단계, 이미지 2/2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Audio Speakers Replacement, Audio Speakers: 4 단계, 이미지 1/2 iLive IKBC384S Audio Speakers Replacement, Audio Speakers: 4 단계, 이미지 2/2
    • Be sure to unscrew (3 mm) the two plastic brackets on each speaker, use iOpener or heat gun they are glued onto speakers, please do not discard.
  5. iLive IKBC384S Audio Speakers Replacement: 5 단계, 이미지 1/1
    • Unplug both of the speakers from the motherboard.
결론
Allen Dover
회원 가입일: 03/21/17
401 평판
안내서 4개 작성하였습니다
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 435
