주요 콘텐츠로 건너뛰기
iLive IKBC384S Disk Drive Replacement
필요한 것
  1. iLive IKBC384S Disk Drive Replacement, Top Cover: 1 단계, 이미지 1/2 iLive IKBC384S Disk Drive Replacement, Top Cover: 1 단계, 이미지 2/2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Disk Drive Replacement: 2 단계, 이미지 1/2 iLive IKBC384S Disk Drive Replacement: 2 단계, 이미지 2/2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Disk Drive Replacement: 3 단계, 이미지 1/2 iLive IKBC384S Disk Drive Replacement: 3 단계, 이미지 2/2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Disk Drive Replacement, Disk Drive: 4 단계, 이미지 1/2 iLive IKBC384S Disk Drive Replacement, Disk Drive: 4 단계, 이미지 2/2
    • Remove all four screws(13.5 mm in length) that are securing the device
  5. iLive IKBC384S Disk Drive Replacement: 5 단계, 이미지 1/2 iLive IKBC384S Disk Drive Replacement: 5 단계, 이미지 2/2
    • Remove both of the connected cords on the motherboard.
    • Also remove the flat ribbon cable that is connected to the motherboard.
    • Once you have removed all screws and cables connected to motherboard the disk drive can be easily removed
결론
Allen Dover
회원 가입일: 03/21/17
401 평판
안내서 4개 작성하였습니다
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 409
