소개
Follow this guide to upgrade your iMac's hard drive with an SSD. It includes steps on installing the SSD's temperature sensor so that the Mac's fans will operate at the correct speed.
Prerequisite-only guide. SSD upgrade with temperature sensor for 2012-2017 iMacs.
도구
부품
Depress the enclosure's front plate latch with your finger. While holding the latch down, swing the plate out.
Remove the front plate.
Peel the backing off of the adhesive back of the small temperature sensor board.
Adhere the temperature sensor board to an exposed, metal area of the surface of the SSD, as close as possible to the SATA connector.
Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 2개
I love the guide~ it is super easy to follow. My computer is not recognizing the disk and I can’t figure out why. I feel like I missed something in reassembly. Any suggestions? Common errors?
Julie Cain - 답글
Hi Julie!
Was the new drive formatted before you installed it? You can try to boot the iMac in recovery mode and reinstall the OS from there. If that doesn’t work, please post your question on our Answers forum and someone may be able to help you out!
