주요 콘텐츠로 건너뛰기
소개
Prerequisite-only guide to replace the logic board assembly in an iMac 27" 2017.
  1. Use a T5 Torx screwdriver to remove the two 4 mm screws securing the AirPort/Bluetooth antenna cables.
    • Use a T5 Torx screwdriver to remove the two 4 mm screws securing the AirPort/Bluetooth antenna cables.
  2. Use the point of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card. Note the original positions for each connector when reconnecting the cables. From left to right on the card, the antennas are connected in the following order: Leftmost
    • Use the point of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables. From left to right on the card, the antennas are connected in the following order:
    • Leftmost
    • Top
    • Upper right
    • Lower right
  3. This is a delicate connection that can be easily broken. Flip up the metal retaining bracket on the iSight camera cable. Pull the camera cable connector straight out of its socket, toward the top of the iMac.
    • This is a delicate connection that can be easily broken.
    • Flip up the metal retaining bracket on the iSight camera cable.
    • Pull the camera cable connector straight out of its socket, toward the top of the iMac.
  4. Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board. Gently push the cable out of the way. Gently push the cable out of the way.
    • Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board.
    • Gently push the cable out of the way.
  5. Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Use tweezers to gently pull the microphone ribbon cable straight out of its socket.
    • Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use tweezers to gently pull the microphone ribbon cable straight out of its socket.
  6. Remove the following screws securing the logic board: Two 23.7 mm T8 screws
    • Remove the following screws securing the logic board:
    • Two 23.7 mm T8 screws
    • One 20.1 mm T25 spacer screw
    • One 17.6 mm T8 screw
    • One 7.2 mm T8 screw
    • Three 7.1 mm T8 screws
    • One captive T8 screw
    • This screw is beneath a hole in the logic board. If you aren't using an iFixit driver, you may need an extension or a screwdriver with a longer shaft.
  7. Pull the hard drive SATA cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port. Don't attempt to completely remove the cable—it can't be removed just yet, but will get in the way of removing the logic board. Don't attempt to completely remove the cable—it can't be removed just yet, but will get in the way of removing the logic board.
    • Pull the hard drive SATA cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
    • Don't attempt to completely remove the cable—it can't be removed just yet, but will get in the way of removing the logic board.
  8. Use a T8 Torx screwdriver to remove the two 5.6 mm screws from the top of the heat sink exhaust duct.
    • Use a T8 Torx screwdriver to remove the two 5.6 mm screws from the top of the heat sink exhaust duct.
  9. When removing and installing the logic board, take care not to damage the delicate microphone ribbon cable at the bottom left of the board. Tilt the logic board slightly forward. Lift the logic board straight up and out of the iMac. Be careful not to snag it on any of the screw posts attached to the inside of the rear case.
    • When removing and installing the logic board, take care not to damage the delicate microphone ribbon cable at the bottom left of the board.
    • Tilt the logic board slightly forward.
    • Lift the logic board straight up and out of the iMac. Be careful not to snag it on any of the screw posts attached to the inside of the rear case.
  10. When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws. You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
    • When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
    • You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
결론
Adam O'Camb
회원 가입일: 2015년 04월 11일
156,922 평판
안내서 418개 작성하였습니다
iFixit iFixit 회원
Community
146 회원들
안내서 17,094개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 47
