주요 콘텐츠로 건너뛰기
iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement
필요한 것
  1. iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: 1 단계, 이미지 1/2 iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: 1 단계, 이미지 2/2
    • This can be a connector within the iMac or another board for parts. I found an unused connector in my computer.
    • Apply the soldering iron to the base of the broken pin connected to the circuit board while levering the tweezers behind it pulling it out slowly.
    • Same as previous step.
    • Slide the pin in the desired connector until it is firmly seated inside.
    • Apply pressure to the base of the pin with the tweezers and solder the pin back in place.
결승점
Mathew Mulligan
회원 가입일: 07/17/17
143 평판
안내서 1개 작성함
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 63
전체 시간: 4,835
