주요 콘텐츠로 건너뛰기
iMac G3 Model M4984 Hard Drive Replacement
필요한 것
  1. iMac G3 Model M4984 Hard Drive Replacement, Logic Board: 1 단계, 이미지 1개 중 1개
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Hard Drive Replacement, Optical Drive: 9 단계, 이미지 1개 중 1개
    • Now to remove the optical drive!
  10. iMac G3 Model M4984 Hard Drive Replacement: 10 단계, 이미지 1개 중 1개
    • The optical drive is located near the front of the assembly.
  11. iMac G3 Model M4984 Hard Drive Replacement: 11 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 11 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Hard Drive Replacement: 11 단계, 이미지 3개 중 3개
    • To remove the drive, push it in, lift up, and then pull forward.
    • As you pull the drive forward, disconnect the ribbon cable and set it aside.
  12. iMac G3 Model M4984 Hard Drive Replacement: 12 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 12 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Hard Drive Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the two phillips #00 screws.
    • Then remove the board. This will reveal that it is a standard PATA drive.
    • Congrats, the drive is free! You can use any PATA-tray loading drive in the iMac G3 which means you can install a CDRW to burn CDs in OS9 or X(if using OSX,install that DVD writer) but, of course only original drives will match the great look of the iMac).
  13. iMac G3 Model M4984 Hard Drive Replacement, Hard Drive: 13 단계, 이미지 1개 중 1개
    • Hard Drive Removal:
  14. iMac G3 Model M4984 Hard Drive Replacement: 14 단계, 이미지 2개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 14 단계, 이미지 2개 중 2개
    • Start by removing these Phillips screws:
    • Now, remove all of these cables:
  15. iMac G3 Model M4984 Hard Drive Replacement: 15 단계, 이미지 2개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 15 단계, 이미지 2개 중 2개
    • Now, remove the optical drive retention spring.
    • Push in on both sides, and pull towards you releasing the retention spring.
    • It may help to do it one side at a time.
  16. iMac G3 Model M4984 Hard Drive Replacement: 16 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Hard Drive Replacement: 16 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Hard Drive Replacement: 16 단계, 이미지 3개 중 3개
    • Now lift the drive up, and pull it out.
    • Make sure that no cables are snagged before completed pulling out the drive!
  17. iMac G3 Model M4984 Hard Drive Replacement: 17 단계, 이미지 1개 중 1개
    • When installing a new drive, make sure that the drive jumper block is set to "Single drive". In most drives, this means removing the jumper, or positioning the jumper horizontally instead of vertically, so you don't lose it.
    • To remove the drive from the metal caddy, remove these four screws from the side of the drive.
결론
다른 40명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
38,086 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
9가이드 댓글
great description, great photos
antiquarian1 - 답글
Many thanks. Worked perfectly.
Bob Schowalter - 답글
is the hard disk on a mac interchangeable to iMac 4984 from iMac M5521? Power supply failed on M5521. thx
alexa pritchard - 답글
Çok güzel. Makul bir para ödemesi yapabilirim.
Erdog ̆an Tas ̧cı - 답글
Thank you so much! My grandmother finally decided to throw hers away but she wanted the hard drive and I got it for her with your help!!!
Heather Hall - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 60
지난 30일: 400
전체 시간: 53,715
