주요 콘텐츠로 건너뛰기
iMac G3 Model M4984 Hard Drive Replacement
필요한 것
  1. iMac G3 Model M4984 Hard Drive Replacement, Logic Board: 1 단계, 이미지 1/1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Hard Drive Replacement: 3 단계, 이미지 1/3 iMac G3 Model M4984 Hard Drive Replacement: 3 단계, 이미지 2/3 iMac G3 Model M4984 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Hard Drive Replacement: 4 단계, 이미지 1/3 iMac G3 Model M4984 Hard Drive Replacement: 4 단계, 이미지 2/3 iMac G3 Model M4984 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Hard Drive Replacement: 5 단계, 이미지 1/3 iMac G3 Model M4984 Hard Drive Replacement: 5 단계, 이미지 2/3 iMac G3 Model M4984 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Hard Drive Replacement: 6 단계, 이미지 1/2 iMac G3 Model M4984 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Hard Drive Replacement: 7 단계, 이미지 1/3 iMac G3 Model M4984 Hard Drive Replacement: 7 단계, 이미지 2/3 iMac G3 Model M4984 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Hard Drive Replacement: 8 단계, 이미지 1/1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Hard Drive Replacement, Optical Drive: 9 단계, 이미지 1/1
    • Now to remove the optical drive!
  10. iMac G3 Model M4984 Hard Drive Replacement: 10 단계, 이미지 1/1
    • The optical drive is located near the front of the assembly.
    Devo sostituire il lettore che modelli potrei cercare in alternativa
    iaco715i - 답글
  11. iMac G3 Model M4984 Hard Drive Replacement: 11 단계, 이미지 1/3 iMac G3 Model M4984 Hard Drive Replacement: 11 단계, 이미지 2/3 iMac G3 Model M4984 Hard Drive Replacement: 11 단계, 이미지 3/3
    • To remove the drive, push it in, lift up, and then pull forward.
    • As you pull the drive forward, disconnect the ribbon cable and set it aside.
  12. iMac G3 Model M4984 Hard Drive Replacement: 12 단계, 이미지 1/3 iMac G3 Model M4984 Hard Drive Replacement: 12 단계, 이미지 2/3 iMac G3 Model M4984 Hard Drive Replacement: 12 단계, 이미지 3/3
    • Remove the two phillips #00 screws.
    • Then remove the board. This will reveal that it is a standard PATA drive.
    • Congrats, the drive is free! You can use any PATA-tray loading drive in the iMac G3 which means you can install a CDRW to burn CDs in OS9 or X(if using OSX,install that DVD writer) but, of course only original drives will match the great look of the iMac).
  13. iMac G3 Model M4984 Hard Drive Replacement, Hard Drive: 13 단계, 이미지 1/1
    • Hard Drive Removal:
  14. iMac G3 Model M4984 Hard Drive Replacement: 14 단계, 이미지 1/2 iMac G3 Model M4984 Hard Drive Replacement: 14 단계, 이미지 2/2
    • Start by removing these Phillips screws:
    • Now, remove all of these cables:
    At this step, the right screw refused to budge. I managed to strip the you-know-what out of it trying to extract it. Every tool I tried, it only got worse. I put it aside for the night and resigned myself to buying some stubborn/rusted-screw-extracting tool the next day. One of the lessons here is rest and walk away if you get frustrated because after a moment of clarity I had a crazy idea. What if I left the screw there and tried to remove the 4 HDD screws THROUGH the holes in the drive cage?! IT WORKED!
    I carefully got to all the screws, simply lifted the HDD out of the still-attached bracket, unplugged the connectors and replaced it with a spanking new 120 GB IDE drive by sticking the screwdriver head into the small holes a la the kid’s game Operation! There is NO WAY I could have done this if 1) I didn’t have a magnetic-head screwdriver (thanks iFixit!) and 2) if there wasn’t an opening at the head of the drive cage on both sides for when the screws fell loose.
    Hope this helps someone. Aloha!
    Joshua Easter - 답글
  15. iMac G3 Model M4984 Hard Drive Replacement: 15 단계, 이미지 1/2 iMac G3 Model M4984 Hard Drive Replacement: 15 단계, 이미지 2/2
    • Now, remove the optical drive retention spring.
    • Push in on both sides, and pull towards you releasing the retention spring.
    • It may help to do it one side at a time.
    Note the orientation of the retention spring. The end towards the back should be pointing upwards.
    Axel Wikström - 답글
  16. iMac G3 Model M4984 Hard Drive Replacement: 16 단계, 이미지 1/3 iMac G3 Model M4984 Hard Drive Replacement: 16 단계, 이미지 2/3 iMac G3 Model M4984 Hard Drive Replacement: 16 단계, 이미지 3/3
    • Now lift the drive up, and pull it out.
    • Make sure that no cables are snagged before completed pulling out the drive!
    If you have trouble getting the drive out, note that there are two small hooks on the underside of the drive cage keeping it in place. Get the hooks out of the holes and the drive will be freed. It can be a bit fiddly.
    Axel Wikström - 답글
  17. iMac G3 Model M4984 Hard Drive Replacement: 17 단계, 이미지 1/1
    • When installing a new drive, make sure that the drive jumper block is set to "Single drive". In most drives, this means removing the jumper, or positioning the jumper horizontally instead of vertically, so you don't lose it.
    • To remove the drive from the metal caddy, remove these four screws from the side of the drive.
결론
다른 39명이 해당 안내서를 완성하였습니다.
Chris Green
회원 가입일: 10/11/09
36,978 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 8개
great description, great photos
antiquarian1 - 답글
Many thanks. Worked perfectly.
Bob Schowalter - 답글
is the hard disk on a mac interchangeable to iMac 4984 from iMac M5521? Power supply failed on M5521. thx
alexa pritchard - 답글
Çok güzel. Makul bir para ödemesi yapabilirim.
Erdog ̆an Tas ̧cı - 답글
Thank you so much! My grandmother finally decided to throw hers away but she wanted the hard drive and I got it for her with your help!!!
Heather Hall - 답글
Oh thats so sad. She threw away a piece of apple history :(
Crosby Grim -
Any idea if I would be able to put a modern 1tb HDD into my iMac G3?
Crosby Grim - 답글
Unfortunately not. The largest drive these machines support is 128GB total but you must partition the drive so that the OS / boot partition is 8GB or smaller. If you want the machine to be faster and more reliable, you can install a 120-128GB solid state drive with an IDE-to-SATA adapter.
Chris Green -
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 51
30일 전: 279
전체 시간: 48,888
