주요 콘텐츠로 건너뛰기
iMac G3 Model M4984 Optical Drive Replacement
필요한 것
  1. iMac G3 Model M4984 Optical Drive Replacement, Logic Board: 1 단계, 이미지 1개 중 1개
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Optical Drive Replacement: 3 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Optical Drive Replacement: 3 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Optical Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Optical Drive Replacement: 4 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Optical Drive Replacement: 4 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Optical Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Optical Drive Replacement: 5 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Optical Drive Replacement: 5 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Optical Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Optical Drive Replacement: 6 단계, 이미지 2개 중 1개 iMac G3 Model M4984 Optical Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Optical Drive Replacement: 7 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Optical Drive Replacement: 7 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Optical Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Optical Drive Replacement, Optical Drive: 9 단계, 이미지 1개 중 1개
    • Now to remove the optical drive!
  10. iMac G3 Model M4984 Optical Drive Replacement: 10 단계, 이미지 1개 중 1개
    • The optical drive is located near the front of the assembly.
  11. iMac G3 Model M4984 Optical Drive Replacement: 11 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Optical Drive Replacement: 11 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Optical Drive Replacement: 11 단계, 이미지 3개 중 3개
    • To remove the drive, push it in, lift up, and then pull forward.
    • As you pull the drive forward, disconnect the ribbon cable and set it aside.
  12. iMac G3 Model M4984 Optical Drive Replacement: 12 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Optical Drive Replacement: 12 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Optical Drive Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the two phillips #00 screws.
    • Then remove the board. This will reveal that it is a standard PATA drive.
    • Congrats, the drive is free! You can use any PATA-tray loading drive in the iMac G3 which means you can install a CDRW to burn CDs in OS9 or X(if using OSX,install that DVD writer) but, of course only original drives will match the great look of the iMac).
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
38,086 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,451개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 33
지난 30일: 117
전체 시간: 18,462
