이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The iMac G3 uses a tray-loading optical drive. It uses a PATA optical drive. This guide will show you how to change your computer's optical drive.
필요한 것
The iMac G3. This was a great computer for the time, and had plenty of features.
Remove the two phillips #00 screws.
Then remove the board. This will reveal that it is a standard PATA drive.
Congrats, the drive is free! You can use any PATA-tray loading drive in the iMac G3 which means you can install a CDRW to burn CDs in OS9 or X(if using OSX,install that DVD writer) but, of course only original drives will match the great look of the iMac).
다른 14명이 해당 안내서를 완성하였습니다.
