주요 콘텐츠로 건너뛰기
iMac G3 Model M4984 Power Supply Replacement
필요한 것
  1. iMac G3 Model M4984 Power Supply Replacement, Logic Board: 1 단계, 이미지 1/1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Power Supply Replacement: 2 단계, 이미지 1/1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Power Supply Replacement: 3 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 3 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 3 단계, 이미지 3/3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Power Supply Replacement: 4 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 4 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 4 단계, 이미지 3/3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Power Supply Replacement: 5 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 5 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 5 단계, 이미지 3/3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Power Supply Replacement: 6 단계, 이미지 1/2 iMac G3 Model M4984 Power Supply Replacement: 6 단계, 이미지 2/2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Power Supply Replacement: 7 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 7 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 7 단계, 이미지 3/3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Power Supply Replacement: 8 단계, 이미지 1/1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Power Supply Replacement, Power Supply: 9 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement, Power Supply: 9 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement, Power Supply: 9 단계, 이미지 3/3
    • Now, remove these screws.
    • Now, lift the bottom cover off.
  10. iMac G3 Model M4984 Power Supply Replacement: 10 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 10 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 10 단계, 이미지 3/3
    • Removing the front bezel:
    • There isn't a great position to put the iMac in to remove the front bezel. I recommend flipping it so it it like it would normally be positioned.
    • Remove these two Phillips screws.
    • Now, work your way around the bezel with a flathead screwdriver, and then, pivot it up towards the top, and remove it.
  11. iMac G3 Model M4984 Power Supply Replacement: 11 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 11 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 11 단계, 이미지 3/3
    • Removing the translucent plastic:
    • Removal of the front bezel will reveal two screw covers on the top, pop them off with a Phillips screwdriver.
    • Now, use a Phillips screwdriver to remove the screws.
    • You can now remove the plastic.
    After taking out the screws, you remove the translucent plastic by pulling the translucent plastic up (if computer orientation is bottom side down), and to the sides, the latches look like hooks and are not pressure latches.
    Do this for each side at a time
    Tal Glazer - 답글
  12. iMac G3 Model M4984 Power Supply Replacement: 12 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 12 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 12 단계, 이미지 3/3
    • Removing the EMI Shield:
    • Remove all 10 of these screws, and lift the EMI Shield off.
  13. iMac G3 Model M4984 Power Supply Replacement: 13 단계, 이미지 1/1
    • Power Supply:
    • Removal of the EMI shield will reveal two major circuit boards.
    • The Display Driver:
    • The Power Supply:
    • The power supply and driver board are dangerous, if you do not know what you are doing, you could severely injure or kill yourself.
  14. iMac G3 Model M4984 Power Supply Replacement: 14 단계, 이미지 1/2 iMac G3 Model M4984 Power Supply Replacement: 14 단계, 이미지 2/2
    • Remove these three screws.
  15. iMac G3 Model M4984 Power Supply Replacement: 15 단계, 이미지 1/3 iMac G3 Model M4984 Power Supply Replacement: 15 단계, 이미지 2/3 iMac G3 Model M4984 Power Supply Replacement: 15 단계, 이미지 3/3
    • Now, swing the board out, and remove the following connectors:
    • AC Power
    • To System Fan
    • Don't remove this. It comes free with the logic board power.
    • To Display Driver
    • The connector that is attatched to the logic board; to remove it, simply thread it through the hole in the metal:
    • Now, you should be able to remove the power supply.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Chris Green
회원 가입일: 10/11/09
36,978 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 한 개
i have exactly this problem with my vintage imac g3 took it to repair shop they said could not find it do you know where i can get this power supply and pay to have it installed
richiezuniga3 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 94
전체 시간: 21,247
