이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The iMac G3. This was a great computer for the time, and had plenty of features.
Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
Remove this Phillips screw.
Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
Then, lift the bottom cover up and out, and set it aside.
Now, remove the DB-15 Video connector from the logic board.
It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
Now, remove these Phillips screws.
Now, grab the logic board assembly by the piece of plastic, and lift it out.
The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
Removing the front bezel:
There isn't a great position to put the iMac in to remove the front bezel. I recommend flipping it so it it like it would normally be positioned.
Remove these two Phillips screws.
Now, work your way around the bezel with a flathead screwdriver, and then, pivot it up towards the top, and remove it.
Removing the translucent plastic:
Removal of the front bezel will reveal two screw covers on the top, pop them off with a Phillips screwdriver.
Now, use a Phillips screwdriver to remove the screws.
You can now remove the plastic.
Removing the EMI Shield:
Remove all 10 of these screws, and lift the EMI Shield off.
Power Supply:
Removal of the EMI shield will reveal two major circuit boards.
The Display Driver:
The Power Supply:
Now, swing the board out, and remove the following connectors:
AC Power
To System Fan
Don't remove this. It comes free with the logic board power.
To Display Driver
The connector that is attatched to the logic board; to remove it, simply thread it through the hole in the metal:
Now, you should be able to remove the power supply.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
i have exactly this problem with my vintage imac g3 took it to repair shop they said could not find it do you know where i can get this power supply and pay to have it installed
