주요 콘텐츠로 건너뛰기
iMac G3 Model M4984 Video Ram Replacement
필요한 것
  1. iMac G3 Model M4984 Video Ram Replacement, Logic Board: 1 단계, 이미지 1개 중 1개
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Video Ram Replacement: 2 단계, 이미지 1개 중 1개
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Video Ram Replacement: 3 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Video Ram Replacement: 3 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Video Ram Replacement: 3 단계, 이미지 3개 중 3개
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Video Ram Replacement: 4 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Video Ram Replacement: 4 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Video Ram Replacement: 4 단계, 이미지 3개 중 3개
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Video Ram Replacement: 5 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Video Ram Replacement: 5 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Video Ram Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Video Ram Replacement: 6 단계, 이미지 2개 중 1개 iMac G3 Model M4984 Video Ram Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Video Ram Replacement: 7 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Video Ram Replacement: 7 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Video Ram Replacement: 7 단계, 이미지 3개 중 3개
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Video Ram Replacement: 8 단계, 이미지 1개 중 1개
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Video Ram Replacement, Video Ram: 9 단계, 이미지 2개 중 1개 iMac G3 Model M4984 Video Ram Replacement, Video Ram: 9 단계, 이미지 2개 중 2개
    • The Video-RAM DIMM slot is located on top of the logic board. Most people confuse this with the system RAM which is hidden under the CPU Shield.
    • The GPU: an ATI 3D Rage Pro Turbo PCI with 2MB onboard + the video RAM DIMM:
    • The Video RAM DIMM:
  10. iMac G3 Model M4984 Video Ram Replacement: 10 단계, 이미지 3개 중 1개 iMac G3 Model M4984 Video Ram Replacement: 10 단계, 이미지 3개 중 2개 iMac G3 Model M4984 Video Ram Replacement: 10 단계, 이미지 3개 중 3개
    • To remove the V-RAM, push the retaining tabs out, and the DIMM should pop up, then pull it out.
    • The 2MB of V-RAM soldered to the logic board:
    • According to what I've read, the iMac will support 10MB Total V-RAM, 2MB onboard, 8MB DIMM.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
38,086 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,454개를 작성함
1가이드 댓글
where can I buy a 8mb video ram chip
Nicholas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 39
전체 시간: 8,892
