소개
Adding RAM will improve performance, especially when multitasking.
필요한 것
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
Release the tabs on each side of the module by pulling them away from the internal RAM
다른 19명이 해당 안내서를 완성하였습니다.
댓글 2개
It's a bit vague. That is, it explains where and how one has access and how the said memory module fits, but most importantly it does not. What kind of memory are we referring to, just as it does not explain the type of memory it has to be and its speed as well as the process of not touching hands with the gold connectors of the memory module
Which memory bank is inside Bank 0 or Bank 1?
