주요 콘텐츠로 건너뛰기
iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement
필요한 것
  1. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Outer Base Plate: 1 단계, 이미지 1/2 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Outer Base Plate: 1 단계, 이미지 2/2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: 2 단계, 이미지 1/1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, RAM DIMM: 3 단계, 이미지 1/2 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, RAM DIMM: 3 단계, 이미지 2/2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Removing the Lower Case: 4 단계, 이미지 1/1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  5. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: 5 단계, 이미지 1/2 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: 5 단계, 이미지 2/2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  6. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: 6 단계, 이미지 1/1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  7. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: 7 단계, 이미지 1/1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
  8. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Internal RAM: 8 단계, 이미지 1/1
    • Release the tabs on each side of the module by pulling them away from the internal RAM
    • Once the tabs are pulled the module will "pop" out and you can slowly remove it.
결론
다른 19명이 해당 안내서를 완성하였습니다.
Lilly
회원 가입일: 10/11/11
632 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-32, Amido Fall 2011 Cal Poly, Team 5-32, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G32
4 회원들
안내서 8개 작성하였습니다
댓글 2개
It's a bit vague. That is, it explains where and how one has access and how the said memory module fits, but most importantly it does not. What kind of memory are we referring to, just as it does not explain the type of memory it has to be and its speed as well as the process of not touching hands with the gold connectors of the memory module
Carlos Sousa - 답글
Which memory bank is inside Bank 0 or Bank 1?
Michael Inman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 18
30일 전: 53
전체 시간: 11,721
