주요 콘텐츠로 건너뛰기
iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement
필요한 것
  1. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Bottom Plate: 1 단계, 이미지 1개 중 1개
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Bottom Plate Housing: 4 단계, 이미지 2개 중 1개 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Bottom Plate Housing: 4 단계, 이미지 2개 중 2개
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 5 단계, 이미지 2개 중 1개 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Drive Carrier Assembly: 6 단계, 이미지 3개 중 1개 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Drive Carrier Assembly: 6 단계, 이미지 3개 중 2개 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Drive Carrier Assembly: 6 단계, 이미지 3개 중 3개
    • Remove the 2 torx 10mm screws on the EMI shield
    • Carefully remove shield and copper tape
  7. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 7 단계, 이미지 2개 중 1개 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the 4 10mm torx screws attatched to the drive carrier.
    • The drive carrier includes optical drive and hard drive.
  8. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Grasp the carrier with both hands on each side.
    • Remove the carrier by lifting up and out.
    • Pull gently but firmly. The carrier is meant to fit snugly.
  9. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Flip the removed carrier to the right and pull out power cables.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Courtney
회원 가입일: 10/06/11
1,106 평판
안내서 3개를 작성함
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011 회원
CPSU-MANESS-F11S21G22
4 회원들
안내서 16개를 작성함
2가이드 댓글
What two screws in step 6
David Hunter - 답글
We need a "action" shot; we need to show an actual screwdriver unscrewing the screw.
David Hunter - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 2,669
