주요 콘텐츠로 건너뛰기
iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement
필요한 것
  1. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate: 1 단계, 이미지 1/1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 2 단계, 이미지 1/1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 3 단계, 이미지 1/1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: 4 단계, 이미지 1/2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: 4 단계, 이미지 2/2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 5 단계, 이미지 1/2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 5 단계, 이미지 2/2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Logic Board Assembly: 6 단계, 이미지 1/1
    • Gently remove the cables marked in red.
  7. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the three metal 10mm T-15 screws.
    • Remove the one nylon 10mm T-15 screw.
  8. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 8 단계, 이미지 1/1
    • Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
    i followed instructions and the logic board is stuck in there! can’t find any answers on the web either. any ideas?
    the biohazard - 답글
결론
다른 9명이 해당 안내서를 완성하였습니다.
Justin
회원 가입일: 10/05/11
303 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011 회원
CPSU-MANESS-F11S21G22
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
We need to say what cables to remove in step 6 of Logic Board Assembly
Courtney - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 46
전체 시간: 10,520
