주요 콘텐츠로 건너뛰기
iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement
필요한 것
  1. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Bottom Plate: 1 단계, 이미지 1/1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Bottom Plate Housing: 4 단계, 이미지 1/2 iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Bottom Plate Housing: 4 단계, 이미지 2/2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 5 단계, 이미지 1/2 iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 5 단계, 이미지 2/2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Drive Carrier Assembly: 6 단계, 이미지 1/3 iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Drive Carrier Assembly: 6 단계, 이미지 2/3 iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Drive Carrier Assembly: 6 단계, 이미지 3/3
    • Remove the 2 torx 10mm screws on the EMI shield
    • Carefully remove shield and copper tape
  7. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 7 단계, 이미지 1/2 iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 7 단계, 이미지 2/2
    • Remove the 4 10mm torx screws attatched to the drive carrier.
    • The drive carrier includes optical drive and hard drive.
  8. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 8 단계, 이미지 1/1
    • Grasp the carrier with both hands on each side.
    • Remove the carrier by lifting up and out.
    • Pull gently but firmly. The carrier is meant to fit snugly.
  9. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 9 단계, 이미지 1/1
    • Flip the removed carrier to the right and pull out power cables.
  10. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Hard Drive: 10 단계, 이미지 1/3 iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Hard Drive: 10 단계, 이미지 2/3 iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Hard Drive: 10 단계, 이미지 3/3
    • Peel back the white paper, revealing the screws that connect the hard drive to the carrier.
    • Remove the 4 T-10 5mm screws connecting the hard drive and frame. (There are 2 screws on each side)
  11. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 11 단계, 이미지 1/1
    • Slide the hard drive out from the frame and optical drive.
  12. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Double check the new drive's jumper: 12 단계, 이미지 1/1
    • Before you reassemble the computer, double check that your new hard drive has the same jumper configuration as the old one. This ensures the IDE "Master-Slave" protocol isn't interrupted. Some systems do not require this, but if you are having issues booting up afterwards with the storage or the disc drive, this could be the source of the problem.
  13. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement, Optical Drive: 13 단계, 이미지 1/1
    • Remove the four T-10 6mm screws at the sides of the drive.
  14. iMac G4 17 800 MHz EMC 1936 Optical Drive Replacement: 14 단계, 이미지 1/1
    • Slide the optical drive out of the carrier
결론
다른 7명이 해당 안내서를 완성하였습니다.
Courtney
회원 가입일: 10/06/11
1,100 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011 회원
CPSU-MANESS-F11S21G22
4 회원들
안내서 13개 작성하였습니다
댓글 2개
Should step ten of removing the optical drive be broken into two different steps
David Hunter - 답글
Which brands/models should one use to replace a faulty optical drive in one of these iMac G4’s?
kenneth.runge - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 4,347
