소개
Keep those electrons flowing by replacing your broken power supply!
동영상 개요
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
거의 끝나갑니다!
결론
다른 35명이 해당 안내서를 완성하였습니다.
